PLLLEEEAASSEEE HELP!!!!
7psib20a5
Car: 93' j-30 and 88' prelude si turbo
ok my 93 j30 will only start if i pull the fuel pump fuse out ,then it will die if i try to put the fuse back in.ive been working on this for almost 2 days and im fed up...and suggestions????
yodawill2000
Car: 94 Infiniti J30
Uh .. That sounds backwards !!You sure thats the pump fuse ??
7psib20a5
yes its the fuel pump fuse....then if i try to put the fuse back in once started it will die.or itll die after it runs out of the reserve gas in the lines
yodawill2000
That is bizzare ..your pump shouldnt work with that fuse pulled.Hopefully a Guru will chime in.Im confused on this symptom
winez31
Car: 1993 s13 ka24de
check the fuel pump relay
7psib20a5
yoda....i was saying the car would only start under NO feul pressure..taking the fuse out.after about 6 hrs. today i think i traced it to the fuel pump resistor.....i never knew it even had one...spec calls for 1.2 ohms........it had0.0 so im gonna replace that and hopefully thats the isssue....if not im leaning twords the fuel pump control moduel.
jons
Not sure how fuel pressure is regulated on a J30, but on at least one car I know of, if the fuel pressure is too high the injectors will not be able to open.
Check the fuel pressure if you can.
Jon.
7psib20a5
well it seems it WAS NOT the resistor....now it still intermetintly starts...some times starts right away some times not for an hour.
J30Guy612
Car: 1993 Infiniti J30
I would try to check the fuel pressure
7psib20a5
fuel pressure is good. i replaced the fuel press. regulator and so far it has started every time. well see whats next.
7psib20a5
well guys it was the f.p.r. its been 2 days and NO starting issues..also the idle is super smooth.thank you all for the input.its very much appreciated.
