Plenums/Spacers/Intake Manifolds-What are you running?
Member area: Post up your ride and the modifications to date
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Like the title says, which Plenum, Spacer, or Intake Manifold have you changed to?
Please fill out the questionaire so that the rest of us will be better informed when we decide to replace our Plenum, Spacer, and/or Intake Manifold.
Please don't chit chat in this thread. It's just as easy to start a new one and ask questions or make comments.
Which G-series: G35/G37, Model Year, Sedan or Coupe, package (if applicable)
Type: Plenum, Spacer, Plenum & Spacer, Intake Manifold
Brand: Self explanatory
Models: For spacers, mention thickness (5/16", 3/8"...etc) and material type if more than one is available. For Plenum or Intake, mention model.
Pros: Butt dyno, sound, stealth look, improved look over stock...etc.
Cons: Sound, tickets, vibrations, FSTB clearance...etc.
Bought at/Price: Where you bought it and for how much.
Comments: Anything you want to add, sound clips or pictures if you're so inclined.
Just click "Quote" on the thread below and fill in the blanks. Delete the "QUOTE & /QUOTE" from your post and then submit. Thank you
Sentientbydesign
96 I30 - Sold
Which G-series:
Type:
Brand:
Models:
Pros:
Cons:
Bought at/Price:
Comments:
Sentientbydesign
96 I30 - Sold
Which G-series: 2005 G35 6MT Coupe
Type: Plenum Spacer
Brand: Blox
Models: Only one available. 5/8" Thermal Polymer.
Pros: When installing the spacer, I found that my plenum was very dirty, so my wife cleaned that while I installed the spacer. The combination of the spacer and cleaning resulted in a much cleaner throttle response with better power. I probably should have reset my ECU for comparison purposes, but I didn't until recently.
Cons: I'm too lazy to reinstall the engine cover
Bought at/Price: Custom Creations (Riverside, CA) $110 out the door (with heavy arguing and negotiation).
Comments: Per my conversation with the tech support, DO NOT apply RTV silicone or any other gasket making substance to the spacer. The thermal polymer will seat itself once it heat cycles. Plus it's somewhat flexible and makes a good seal. Also, because of the flexibility, the holes may not line up with the plenum. Just tweak the spacer a little hear and there before you tighten all of the bolts.
Supposedly this mod for my MY is best coupled with the MREV2 lower plenum which is actually a modified AT lower plenum.
TeflonG35
Car: 2003 G35 Sedan
Which G-series: 2003 G35 Sedan AT
Type: Plenum
Brand: Kinetix Plenum V+
Models: VQ35DE
Pros: Increased volume of air. 50 Degrees cooler then stock plenum. Power Gains.
Cons: engine cover may not fit with the G35 or the FX35
Bought at/Price: $300
Comments: Easy to install with simple hand tools. Throttle body can be a pain.
G_whizz
Car: 2010 G37 Coupe Sport
Which G-series: 07 Coupe 6MT
Type:
Brand: Motordyne
Models: 5/16
Pros: More power
Cons: Use more gas because I'm addicted to the increased power
Bought at/Price: $260.00
Comments: Great mod... but works better when coupled with the MREV. By itself, there would probably be no noticeable power increase.
joe603
Car: 2014 Durango R/T
Which G-series: 2005 G35 coupe
Type: Plenum & Spacer
Brand: Motordyne
Models: 5/16 spacer, MREV2 plenum
Pros: more HP throughout the powerband, especially after 3k. Easy install, excellent quality.
Cons: Expensive...but worth the cost
Bought at/Price: $130 spacer, $470 MREV2
Comments: Mandatory mods for a REV-UP G!!!
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
350Z
Type: Plenum
Brand: Kinetix Racing
Models: V+
Pros: Light weight (weight reduction), more air, nice aggressive sound, easy install
Cons: N/A
Bought at/Price: $300ish well worth it
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Which G-series: 2003 Sedan
Type: Plenum Spacer
Brand: BLOX
Models: 5/8"
Pros: Sound/Power/Cost/easy install, faster rev
Cons: none that I noticed
Bought at/Price: $105 shipped
Comments: I like the way the Spacer feels and sounds. The cover fit on with very little extra effort in modifying it.
Alpha Ice
Car: 2005 Infiniti G35 6mt
Type: 5/16" Plenum Spacer, mREV Lower Collector
Brand: Motordyne
Models: 5/16"
Pros: Well first off, it actually quieted my car down, but I already had a few mods going. I noticed a nice pickup in the lower rpm range and higher pull after 4k. Clean look and a nice setup, power gains were noticable and surely quieter
Cons: None that I had, no modification was necessary, the Copper TB setup was a pain in the butt, but yay for MN :oP
Bought at/Price: Spacer was from Riverside Infiniti $300ish(g35driver.com) and Lower collector was from MD, standard $400 price.
Comments: Currently I'm running an Injen CAI, the spacer and lower collector, UR Pullies, Kinetix HFC and Injen SES exhaust, but I do have some sound clips of after mREV and before http://www.youtube.com/user/ackilles85 . This is the first manual I've learned to drive and this year was my first year driving it so be nice
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
Which G-series: 2005 G35X
Brand: Motordyne
Models: 5/16th basic
Pros: Relatively easy install, improves low and mid range (after 4k rpm) pull, great new sound after 4k rpms
Cons: must use a torque wrench to install, and has like 18 bolts that need to be installed in the right order, not hard a hard install, but just not for the impatient
Bought at/Price: $200
Comments: if you have $200 to spend on an intake... get this first
tollboothwilley
Which G-series: 2003 Sedan (fits 2003-2006 coupe/sedan)
Type: Plenum spacer
Brand: Motordyne
Models: 1/2" Copper Iso Thermal
Pros: Better gas mileage, sound, 4 whp/4 tq more than BLOX
Cons: cost $295 new I think
Bought at/Price: $180 ( new copper iso and used 1/2")
Comments: I changed from the Blox 5/8" spacer to the Motordyne 1/2" while I was at the dyno. I gained 4 HP and 4 TQ to the wheels. It was enough info for me to stick with Motordyne. I also bought the Copper TB bypass with the aramid gasket.
Modified by tollboothwilley at 2:10 PM 1/18/2010
tollboothwilley
Type: Lower Plenum
Brand: Home Brew
Models: Polished, machined lower collector, port matched (MREV2)
Pros: Better everything
Cons: none.
Comments: Much better response at lower rpms and 4000+ rpms. Better power, but leaned me out. Needed to adjust the tune.
Return to “G35 and G37 Modification database”
