Plenum-to-union vacuum hose (brake booster)
jnever1
Car: 1995 Infiniti Q45, Base in graphite on Cabernet
Hello,
Today I successfully replaced KS on my 95 Q45. The only casualty was the vacuum hose that runs from the back of the plenum to a union (and then on to the brake booster). Without boost, stopping my Q is like trying to stop a freight train! Any suggestions for a replacement?
I am in Michigan.
Thanks!
Q451990
Order them from a dealer, or one an online source like www.orderinfinitiparts.com. You could rig something from parts store hose - but I would feel better with the OEM part for something as critical as stopping.
Heath
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Also, that's a one-way hose, isn't it? It is on my y33, pretty sure, installed it backwards and brakes were messed up once.
jnever1
paranoidjack,
The union the broken hose butts up to is the check valve on my Q, so no drawkab worries, but thanks for the words of caution.
ref: http://www.autopartswarehouse.com/detai ... 20540.html
Heath,
I'll make some calls tomorrow for the part. Might try two straights and a 90* if I can't get OE by Friday.
Thanks for the replies.
I plan to replace O2s tomorrow and you've helped ensure the Q is purring before date night! :-).
