6mt. Also I've heard mixed things about including the stock plenum gasket in the re installation of the top plenum, and whether or not to use a silicone sealant.joe603 wrote:5/16 will be easier. The gains from the 1/2 will actually less overall.
Do you have a 6MT or Auto.
+1bina12834 wrote:whats the difference between the regular, ISO and ISO Copper?
Poyzinous wrote:Get a 14oz Strip steak medium with seasoned house fries and the cornbread. Its delicious. Also tell the bartender you want the extra large draft beer glass. The waitress always says you can get the 16 or the 20. But you have to secretly request the 28oz megamug. Pretty much all their desserts are delicious. I like the Browniecake thing with ice cream.
I was definitely looking into the pop charger, but instead of the ztube I was thinking about the stillen hi flow. I don't really like the plastic look of the ztube.joe603 wrote:If you have the 6MT, I HIGHLY recommend you also get the MREV2 lower plenum from Motordyne. With the MREV2 and the spacer, your engine will sound 10x better then OEM, with a nice boost of HP in the usable RPM range.
Finish it off with a popcharger and the Z-tube.
The copper has an additional layer of metal to help with heatsoak. Check out motordyne's website for more info:
http://www.motordyneengineering.com/
Not very. The only specialized tool that you'll "need" is a torque wrench.Joey666Crack wrote:How difficult would it be to install the mrev?
wheres a good place to get the grounding kit? someone on here make and sell them?BrandAidDesignG35 wrote:The mods you listed would help you chirp in 2nd, but don't forget grounding wires for the AT... good times.
it says to get the copper one if you get snow in your area....im in northern virginia where we get snow sometimes, but not like maine or michigan.....do i need to get the copper one?joe603 wrote:The copper has an additional layer of metal to help with heatsoak. Check out motordyne's website for more info:
Got to learn how to drive the car, Joe. Keep it above 2k RPMs for all gears and don't try to accelerate when you have low torque multiplication.joe603 wrote:A lightweight flywheel will make the car sound like a dumptruck...I'm going to put my OEM dual-mass back in eventually.
The flywheel does nothing for HP gain...only faster acceleration/deceleration.
what about the MREV2? can us AT owners use that too, or is that strictly for the MT owners?
Keeping the car at 2k sounds easy...but trying to go slow in school/town zones and under 2k in second gear is the norm (shifting back into 1st is a no-no). Not to mention stoplights, drive through windows, traffic, and any other time the car is idling. With summer and the AC being used, the sound is really loud and annoying. If I had to do over, I would have kept the OEM flywheel on and only put on a stage 2 clutch.Sentientbydesign wrote:
The lightweight flywheels allow a significant amount of torque to be applied directly to wheel acceleration instead of flywheel acceleration. That's comparable to having increased HP
I didn't say it increased HP, I said it was comparable to increasing HP. I personally don't care how more torque gets to the wheels, I just want more torque to the wheels lol.joe603 wrote:
I still disagree with you on the notion that a lightweight flywheel will increase HP...it will only make acceleration/deceleration quicker and more abrupt. Having a clutch with increased grip will apply the torque faster, and thus faster transfer of power.
