I don't have the need to use the bypass, doubt I will install it.joe603 wrote:The MREV2 or the spacer comes with the coolant bypass valve...you don't need to bleed the system.
Welcome to NICO!Torqd wrote:Whats the benifit of said spacer?
Cool thanks, I'm soon to be the proud owner of a 2007 G35 coupe. I've never owned an Infiniti before so I'm new to all of this.joe603 wrote:
Welcome to NICO!
The VQ35 has a design problem with the front cylinders, the spacer allows more air to flow and to even out each cylinder intake. For the 05+ 6MTs, the MREV2 lower plenum will give even more of a boost in total air intake.
Search the boards for more info.
