PLENUM SPACER HELP
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
I'm installing the plenum spacer right now. There are the 2 studs that need to come out and I cant get them out. What did you guys use to get these bolts out
Use the old "two-nut" trick.
Thread a nut down the stud halfway. Thread another one down on top of it, and tighten them together (so they snug against each other).
Then, using a small open-ended wrench on the lower nut, back the stud out. The lower nut will act like a bolt head.
Alternatively, the top of those studs fits nicely into a small metric socket (can't recall which size though).
joe603
Car: 2014 Durango R/T
What size spacer did you get?
tollboothwilley
I'm tryin out the BLOX 5/8"
4mm hex-head did the trick
let ya know after i drive
