From the picture below, I believe I need to remove bolt at (A).
Should both (B) and (C) be removed or just (C)?
There seems to be a line behind the part where I need to gain access for releasing the hose clamp.
Amen!tfitzs01 wrote:I second the syl-glyde...
Also, if you are replacing injectors, make sure that they are screwed down evenly. (e.g. One turn of each screw at a time.)
I screwed up two o-rings last week because of poor diligence to that simple fact! Repeating a removal after a muck-up is like punching yourself in the face after a root canal.
tfitzs01 wrote:Repeating a removal after a muck-up is like punching yourself in the face after a root canal.
With the engine hot it will pop off without damage with gentle but steady prying under one of the long edges with the tip of a small screwdriver.Q451990 wrote:......The center emblem on the plenum is just stuck on there with double-sided foam tape. The other parts are part of the plenum.....
OwnerCS wrote:While I like the looks of an outwardly shiny engine, I am really going for clean and protected internals.
Yesterday the plating guy referred me to another service he says can do better with nickel plating the insides of the injector rail and fuel lines.
I will be researching threads for information on cleaning the EGR and IAC valves.
The good news about all this is the old injector screens were clean as a whistle. That was a nice surprise.
Also the first thing before I started the job was to evacuate the fuel system (3) times -- following a recommendation from an airplane and yacht mechanic that is known for cleaning up some bad fuel contamination problems. I did not find any contaminants in that process either.
Now I have it filled with 100% premium. Luckily, I found a station a few miles from home that sells real gas -- for the time being.
I aim to cut open the old fuel filter when I have some spare time -- which might be a while from now.. :-)
If it was anywhere else but T3, I'd agree with you - but I'm pretty sure that it is their SOP to clean everything that's off. They even spent a good bit of time cleaning my rocker covers on my Q and they only had 47K of buildup on them. Possibly less than that since it was their second reseal. Pretty sure they cleaned the plenum on my old Q when they had it off too.qship96 wrote:plenum has only been off 1x in its life,at 203,000 miles when T3 did the underplenum job{hoses/knockers}....seriously doubt they took 1 extra second to clean it
Dennis used to joke that the insulation for the knock sensor subharness was made out of recycled Big Mac wrappers! For some reason they always get that one... I had one that was stripped too, but I think it was from incompentence by a dealer tech. that had worked on the car, it was all around one of the cable tie tie-downs, like the wire had been pulled really hard and the insulation was stripped as a result.OwnerCS wrote:looks some varmint chewed off the wire insulation.
