We are removing he plenum to replace the fuel injectors. I have a couple questins I know you guys will have the answers to:
1. How many bolts attach the plenum, There are 7-8 easy to access ones on the top of the plenum and 4 on the underside attaching 2 vacume tubes. How many others are hidden under and to the sides.
2. When we removed the fuel injector electrical conections the clips were very brittle and several retaining rings broke in the process. They appear to still make god tight connections. Do I need to replace them?
3. If I buy new injector harnesses where do they connect. The existing harness is wraped with the coil pack wires and is difficult to trace. How difficult is it to replace the harnes?
Thanks.
Modified by nick22 at 6:23 AM 7/1/2007
