plenum pull parts list?
zswap0429
Car: 1990 Nissan 300zx N/A (sold)
1990 Nissan 300zx Twin Turbo. (sold)
1993 Nissan 300zx N/A Convertible (sold)
1991 Nissan 300zx N/A (Project)
2009 Nissan Altima 3.5 SE 6spd.
Ok so when I get home I plan on doing a simple plenum pull to replace some of the gaskets and such. Possibly also do a 60k tune up.
This is my current shopping cart from z1. Am I missing parts for the plenum part of it? All smaller hoses will be bought at a local auto store.
Plenum parts
Balance tube o-ring set x1 $9.85
Z1silicone idle air hose set (na) x1 $48.00
-black
Throttle body gasket set (pair) x1 $6.00
Idle air gasket (iaa/iac) x1 $2.48
Z1 silicone pcv hose set - non turbo x1 $64.00
-black
Z1 silicone brake booster hose set x1 $29.00
-black
Nissan valve cover gasket kit x1 $58.00
-egr to plenum gaskets
(Includes plenum gasket, lh&rh valve cover gaskets, 2 half moon rubber seals, 1 tube ultra grey silicone gasket maker)
Other
Boost leak tester x1 $24.00
-with pressure gauge
Z logo battery tie down x1 $16.00
60k (still debating)
Nissan oem 60k-120k timing kit x1 $474.00
-model na
-year 1992
-accessory drive belt for stock pulleys
-include spark plugs
Total: $731.33 plus tax
Local pickup so no shipping. :)
Ok so the purpose of this is to find and fix a vacuum leak I've been fighting for about a year now. I figure doing this work will not only help me find the leak. It will also help me prevent a future problem.
Before anyone suggest anything crazy... all I want to do is fix and strengthen this motor. Its still rolling on 45k miles so there is no need to go crazy. Plus im saving to build the tt motor that I already have. However all suggestions are welcome.
Thanks in advance.
300ZXttZMAN
You can swap out the rubber half moons for the BDE billet aluminum half moons, because they are more reliable.
Other than that I think your on point.
Rager
Car: 1992 Nissan 300ZX 2+2
1999 Nissan Sentra
2004 Chevy Silverado
if your replacing fuel lines makes sure to get high pressure fuel lines. i believe regular fuel lines arent enough. if someone wants they can confirm what im saying.
300ZXttZMAN
Rager wrote:if your replacing fuel lines makes sure to get high pressure fuel lines. i believe regular fuel lines arent enough. if someone wants they can confirm what im saying.
J30R9 is what you need.
zswap0429
Im not going for any type of power increase on this. So do I really need better fuel lines?
zswap0429
And the rubber stoppers come in a package deal so I dont want to get the other ones because then ill just have an extra set laying around.
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
oem fuel line is best though pricy. But yes you need a hp fuel injection hose whether it's oem the j30r9 etc.
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Stock NA or TT, doesn't matter, a J30R9 fuel line is required. Given the frequency you'll be replacing them (rarely) it makes sense to use OEM, as it's also the best fitting.
The OEM rubber half moons are fine, but the BDE ones you never have to replace once you buy them once.
If you're due for the 60K, get the kit as well. Maybe they'll give you a package deal. Get the silicone coolant bypass hoses as well. They're cheaper than stock and last forever.
Do the throttle body coolant line bypass as well. If you live in Georgia, there's no reason to have them, and they'll just leak in the future. You can use Z1's silicone coolant line for that as well.
zswap0429
Thanks. Im thinking about holding off on the 60k kit because I still have over 15k miles before I need them. And ill look into the other lines as well. None of those bypasses effect emmissions right?
zswap0429
Update:
So I said screw the 60k kit for now... not needed for a while. Instead I added these items
99 jdm tail lights x1 $440
Z1 chrome gauge rings x1 $38
300zx fuel line kit x1 $35.51
I am going to hold off on the coolant bypass hoses. Until I do my 60k
And if someone could send me a link to the throttle body lines that would be appreciated
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
The time to do the coolant line delete/bypass is with the plenum off as they are under it. No it wont effect your emissions at all.
zswap0429
I thought coolant lines are supposed to be done when you do a 60k
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
The first time you pull the plenum off you should delete the TB coolant lines. It will make pulling the plenum in the future MUCH easier. The 60k kit is really just replacing the timing belt/water pump/tensioner etc. on the front of the engine, not pulling the plenum off. They really aren't hard to delete once you get the plenum off.
And FYI I used auto parts store fuel line on mine, you just have to make sure its FUEL INJECTION hose not just fuel hose. Usually you have to specifically say fuel injection hose. Regular fuel hose will swell/balloon up (ask me how I know). The fuel injection hose I bought at AutoZone was rated at 10 bar (145psi) and it's held up great to the ~45 psi our fuel system pumps out.
t.mcginley.jr
1966 Ford Mustang
This is turning into a tech thread.. lol
Rager
1999 Nissan Sentra
we are just here to help :dblthumb:
300ZXttZMAN
zswap0429 wrote:And the rubber stoppers come in a package deal so I dont want to get the other ones because then ill just have an extra set laying around.
Who are you buying from? Most vendors will substitute them out and you would then just pay the difference.
edit: Now I see that your holding off on the 60k kit until it gets closer to time.
zswap0429
All the items listed are coming from z1.
And what do I need for the tb bypass.... and how do I do it? Any write ups out there?
BigTDogg (MA)
t.mcginley.jr
1966 Ford Mustang
BigTDogg (MA) wrote:http://s95014253.onlinehome.us/63104/16304.html
Last fish of the day :)
Wow I've never seen that method of removing injectors, GENIUS!!
BigTDogg (MA)
Robo is a very smart dude, just had a real heavy foot so he got out of the Z "scene" (I hate that word) for a while. He'll be back though, me thinks.
zswap0429
Ok just looked at that article and I have a quick question. Isnt there some type of open end that will be left somewhere that needs to be blocked off. Im not with my car right now or else I would just look at my engine myself. Sorry if I sound like a complete moron with these questions... I've always been a hands on learner.
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
Without a pic to see what part your talking about exactly it's hard to give a better answer, but basically your deleting the lines under the plenum and looping the coolant to complete the flow cycle still on the backside of the plenum into the two large lines that run into the firewall for the heater core. A tt has a little more with to do than a n/a but not to bad.
