So, I found another mistake I made . . .
Last night, like I said, she started up and ran pretty darn well. A little sluggish, but it idled smoothly. So I go to start it tonight, and no start. I got just a little hint of it firing for a split second, then nothing. Cranking but no fire Checked and had fuel flowing and no leaks, so i checked the spark and nothing!!! Looking around, I found I'd failed to connect the ground at the rear drivers side of the plenum. Reading about this, it looks like this can wreck a PTU. (btw, it's the new style). Im assuming the loose ground was laying somewhere that it was making a little contact last night, but that it moved and lost a connection. Then, it turned over, the plugs all soarked once, and this was the kiss of death
I pulled it off and couldn't get continuity anywhere from any of the pins trying every combination I could think of. The fsm writup wasn't very clear to me. I did reverse polarity for each combo. I'm assuming this means it got toasted.
I also checked to make sure the ignition relay was working. According to what I read, 12 v coming from the center slot of the coil pack clip means that this is ok. I couldn't find anything about a fuse that may have blown.
Does this all sound reasonable? Is there something else I should look at before I order another PTU?
I hate to keep sounding like a cheapskate, but I found some used PTUs on eBay for $24. Much less than the $160+ I saw for a new one. Are the new PTUs enough more reliable that I could feel comfortable with a used one? I was thinking of just buying 2 so I could have a spare. Is this smart shopping or a really bad plan.
Ps. I have a new oem knock sensor and harmess on the way.
As always, thanks a ton.
Scott
