maxnix »
https://forums.nicoclub.com/maxnix-u127.html
Wed Aug 06, 2003 5:40 pm
Here is a complete 'hose order'for a 1995 Q45/t non-TCS. (with knock sensors and harness thrown in for good measure.)
Thanks to Frank and Joe at infinitipartsusa.com (888) 216-5328 for revising and completing this order.
These are the exact terminology used by infiniti (useless, eh?) You'll need 8 of the manifold gaskets,
HOSE ROCKR CVR 11826-60U68HOSE ROCKR CVR 11826-60U69HOSE-BLOW BY,A 11826-67U24HOSE-BLOW BY,A 11826-60U65HOSE-BLOW BY,A 11826-60U67HOSE ASSY-BLOW BY,A 11823-60U62HOSE ROCKR CVR 11826-60U66HOSE ROCKR CVR 11826-64U61HOSE ASSY-BLOW BY,A 11823-60U60HOSE ASSY-BLOW BY,A 11823-60U61HOSE-AIR 14099-60U60HOSE-AIR 14099-60U63HOSE-AIR 14099-60U61HOSE-AIR 14099-60U09HOSE-AIR 14099-60U06GASKET-INTAKE MANIFOLD 14032-60U01GASKET-THROTTLE CHAMBER 16175-61U00GASKET ACC VALVE 23785-60U01GASKET-EGR CONTROL V 14719-W7001
Total on hoses was around $370.
HOSE-WATER, BYPASS 14055-F6511HOSE-WATER 14055-60U60HOSE-WATER 14055-60U70HOSE-WATER 14056-60U09HOSE-WATER 14056-60U00HOSE-WATER 14056-60U05HOSE-WATER, BYPASS 14056-60U08HOSE-WATER, BYPASS 14056-64u10HOSE, 14056-64u08HOSE, 14056-64u00
RADIATOR HOSE-UPPER 21501-60U10RADIATOR HOSE-LOWER 21503-60U10
HOSE-FRONT HEATER,1 92400-61U20HOSE-FRONT HEATER,2 92410-61U20
and two knock sensors.
SENSOR ASSY-KNOCK 22060-30P00HARNESS-ENGINE SUB 24079-60U00
The last pair are the heater hoses to the firewall. The second to last pair are the radiator hoses (I think). Another $45 for the plenum hoses, $20 for the two radiator hoses, and $75 (wow) for the two heater hoses...
Heater Core Code: Turn ignition on, press HVAC off button within 10 sec and hold for 5 sec, press hot 3 times, press defrost 2 times, display should read 43, wait 10 sec before turning ignition off. Good luck!
