Qdog »
https://forums.nicoclub.com/qdog-u384.html
Wed Aug 06, 2003 12:50 pm
I got the plenum off (for the first time) in around 5 hours, working carefully, closing off & IDing most hoses so I know how they go back. No scrapes, no cuts, no damage even to old hoses. I was expecting a really grunged up TB & plenum at 160K & no record of a cleaning, but it just has a thin brown layer. 1) Should I remove the lower runners to clean this thin deposit ? I'm worried about all the grit down there falling into the heads if I do. 2) Will new gaskets be needed between lower runners & heads ? While I'm in there, I thought I'd remove the injectors, ohm test, and take them to a shop for cleaning, or do it myself with pressurized solvent. 3) What is the best cleaner to use off the car that will be safe for the injector coil insulation ? The manual say not to apply battery voltage directly to the injectors, but how else are they going to open for cleaning. I assume a quick pulse to the injectors will be safe, but not continuous 13.8. 4) Do they receive full battery voltage in normal operation ? I could borrow an O-scope & check, but things are already apart. 5) Are new O rings & lube needed to re-install injectors ? Thanks for your help & ideas.
