duck3986 »
https://forums.nicoclub.com/duck3986-u4892.html
Sun Sep 26, 2004 10:32 am
I had hoped I'd be able to remove the plenum only and not the runners to replace my knock sensors but ended up having to remove the runners too.
It was more complex than I expected.
So everything's off the car. I'm not sure if this was the right procedure, but I cut the two fuel hoses (to be replaced later) which connect the fuel rails so that I could remove the runners. In doing so, i damaged some of my fuel injectors, but I'm not sure how serious the damage is.
On the bottom of eache injector, where the tiny holes are that shoot out the gas, there are four plastic "fingers" or "clips" that seem to hold the metal injector tip. There seem to be two or three of these "fingers" missing on the left injectors. They broke off when I was wiggling the runners out.
How serious is this?
I was thinking about bringing the injectors to a shop to have them bench tested since I have everything apart and the car has 94k miles.
Is this a good idea? Do I just disconnect the fuel rail and bring it as an assembly or do I remove each individual injector?
What should I request the shop to do? Flow rate? Have them pressure cleaned?
Anyone know what I should expect to be charged to do this?
Thanks,Don
