Qdog »
https://forums.nicoclub.com/qdog-u384.html
Wed Oct 08, 2003 6:07 pm
Finally got the car back together 2 months after starting the plenum job. Half the time was waiting for parts, I'm not that slow. Thanks, Doug, for the 4 injectors. They seem to be working well. All 8 have been ultrasonically cleaned off the car, did the fuel rail (it looked good anyway), new plugs, cleaned the TB & entire plenum off the car, replaced all hoses, knock sensors, harness, cleaned the injector harness contacts, cleaned IAC. Also replaced the fuel pump for good measure. Put it all back together, no leaks. The trickiest part was replacing the coolant bypass hoses in the valley. Two hard fittings with permatex and a large hose connection to be made at the same time. The knock sensor contacts were green with corrosion, my four injectors tested at around 70% rated flow before cleaning, but the TB looked pretty good. At the last stage of reassembly, I pulled apart one of the small hoses to the TB and found a bottle brush lodged in the hose ! I've had this car 3+ years, I didn't leave it there ! Also, the Plenum to runner gaskets had irregular applications of red permatex on them. The previous injector replacements had been done by Infiniti of Bloomington...I was hoping for a dramatic improvement in performance, but it wasn't all that. It's smoother & stronger in the mid-range, and that annoying shudder when taking off from idle is gone. It idles at the same speed, smoother but not perfect. 16.5 mpg on the first (oxygenated 93 oct.) half-tank, plenty of idling & high rpms. Any suggestions pursuing the perfect idle ?
