plenum hose repair
340valnt
Well I figured i share what i come up with http://grubbsinfinitiparts.com/ Use this web site for pulling part diagrams Use this website http://nissan.epc-data.com/infiniti_q45/g50/2239-vh45d/
to take diagram reference numbes and convert to part #s for different yrs.
It took me awhile to get efficient with this but it will work. Here is my excel list with part # description reference #. The reference # is the diagram # with part book heading & sec #
Hope it helps
11823-67u00 hose assy blow by 11823 CRANKCASE VENTILATION sec 118 a01
11826-60u69 hose rocker cvr 11826 CRANKCASE VENTILATION sec 118 a01
11826-60u67 hose blow by 11826 b CRANKCASE VENTILATION sec 118 a01
11826-67u00 hose blow by 11826 c CRANKCASE VENTILATION sec 118 a01
11826-67u24 hose blow by 11826 g CRANKCASE VENTILATION sec 118 a01
11823-64u60 hose rocker cvr 11823 a CRANKCASE VENTILATION sec 118 a01
11826-64u61 hose rocker cvr 11826 a CRANKCASE VENTILATION sec 118 a01
11823-60u61 hose assy blow by 11823 c CRANKCASE VENTILATION sec 118 a01
11823-67u20 hose assy blow by 11823 b CRANKCASE VENTILATION sec 118 a01
11826-60u66 hose rocker cvr 11826 e CRANKCASE VENTILATION sec 118 a01
11826-60u68 hose rocker cvr 11826 d CRANKCASE VENTILATION sec 118 a01
14056-60u08 hose water bypass 14056 m WATER HOSE & PIPING sec 211 a01
14056-60u05 hose water 14056 nb WATER HOSE & PIPING sec 211 a01
14055-f6511 hose water bypass 14055 ma WATER HOSE & PIPING sec 211 a01
14056-60u00 hose water 14056 n WATER HOSE & PIPING sec 211 a01
14056-64u04 hose water 14056 na WATER HOSE & PIPING sec 211 a01
14055-60u60 hose water 14055 m WATER HOSE & PIPING sec 211 a01
14055-60u70 hose water 14055 mb WATER HOSE & PIPING sec 211 a01
14099-60u09 hose air 14860 n SECONDARY AIR sec 148 b01
14099-60u60 hose air 14860 nb SECONDARY AIR sec 148 b01
14099-60u61 hose air 14860 na SECONDARY AIR sec 148 b01
14099-64u61 hose air 14860 nd SECONDARY AIR sec 148 b01
14099-67u00 hose air 14860 nc SECONDARY AIR sec 148 b01
47471-60u00 hose booster 47474 BRAKE SERVO & CONTROL sec 470 01
47474-60u00 hose booster 47474 a BRAKE SERVO & CONTROL sec 470 01
21501-60u10 hose radiator upper 21501 RADIATOR SHROUD & COOLING sec 214
21503-60u10 hose radiator lower 21503 RADIATOR SHROUD& COOLING sec 214
22320-64u08 purge cann hose 22318 ENGINE ELECTRICAL CONTROL PIPING sec 223 01
b2318-n3301 vacuum line 22310b ENGINE ELECTRICAL CONTROL PIPING SEC 223 01
16175-61u00 gasket throttle rear 4 hole 16293m ENGINE MECHANICAL MANIFOLD sec 140 02
16175-64u02 gasket throttle frnt 3 hole 16293 FUEL & ENGINE CONTROL THROTTLE sec 163 b 01
23785-60u01 gasket idle air 23785n SECONDARY AIR sec 148 b 01
140351P100 gasket intake lower 14035 ENGINE MECH A MANIFOLD sec 140
1403260U01 gasket intake upper 14035p ENGINE MECH A MANIFOLD sec 140
3139751X02 gasket trans pan 31397 POWER TRAIN F GASKET & SEAL AUTO sec 312
3172851X08 strainer trans 31728 POWER TRAIN F CONTROL VALVE sec 317
21640-67U00 filter trans kit 21640p POWER TRAIN F TRANSAXLE & FITTING sec 310
11950-60US4VW belts power steering 11950n ENGINE MECH A FAN COMPRESSOR sec 117
164000-41b1a fuel filter 16400 FUEL CONTROL B STRAINER & HOSE sec 164
11720-60US1VW belts alternator 11720n ENGINE MECH A FAN COMPRESSOR sec 117
11920-60US1VW belts compressor 11920n ENGINE MECH A FAN COMPRESSOR sec 117
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
http://nissan.epcdata.ru/
For some reason the russian version of this site has all the pictures and diagrams
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I know also we have the parts diagrams on here somewhere... I know I had all of that posted at one point in time many years ago.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
On Q45,org ?
elwesso
2007 BMW M Coupe
No I think I posted them here on NICO. I know I have all the diagrams and whatnot on my computer, I could probably repost them.. I also had a list that cross references the part codes on the diagrams to the part number on the hoses and other pieces.
