jimbyjimb »
https://forums.nicoclub.com/jimbyjimb-u93878.html
Tue Apr 29, 2008 6:50 pm
You don't need to use a torque wrench on the plenum bolts. Tighten em up, plus a smidge.You could probably rig up something using spacers and the correct bolt, but those particular bolts are a dealer item. No need for spares unless you butterfinger 'em, and these bolts are fairly tough to drop since they fit into a little sleeve. The only things you would really need a torque wrench for are things like headbolts or mains, suspension pieces... By feel is fine. Tighten from the middle out on intakes. I promise you there is no mechanic in the world that uses a torque wrench on intake bolts unless the shop is slow slow slow or there is a special circumstance. There are alot of "strictly by the book" people on here, which is fine, but it's all opinions and they all smell like butts, present company included. 90% of the bolts on any car can be done by feel only, regardless of the fact that there is a torque spec for every single bolt.
