So does this mean it is normal? The fluid looks super clean and smells fresh.Q45tech wrote:Transmission are really not designed to function very well until warmed to operating temperature just as high performance engines often object.
The AT has a temperature sensor which changes shift pressure to try to maintain reliability and smoothness.
When the fluid is old and dirty, the preprogram is wrong, when the transmission internal are worn the pump may not supply enough pressure or the pressure may leak away before it does the job.
JATCO trannies usually last thru warranty and if well maintained and not abused can last 200,000 miles. Time is important inthat 10 years is the functional equivalent of 150-200K.
All depends on when you go thru the 100,000 shift cycles not miles as city is 3-10 times worse than just interstates.
maxnix wrote:Tell us how it operates at normal operating temperatures.
Not too sure that this is true on my '99 is it? Just looking at the tubes I think my transmission pumps it's fluid right to the radiator, (no aftermarket cooler.....purchased but not yet installed) so as the coolant heats up so does the ATF.....right?maxnix wrote:A 30° F, it should take about 5 minutes or so to reach operating temperature. Even then, only your engine and transmission casing by conductance is warm. ATF is cold.
Not sure what you mean by the first comment but thanks for the help.maxnix wrote:http://www.infinitipartsusa.com
If you decide you don't want to muck around playing amateur pit monkey.
http://www.bgfindashop.com
Don't forget the extra crush washers.
Oh, that's just Brian's abrasive way of saying that it would probably be easier and almost the same price (since you'd only use 14 quarts of AFT), with marginally better results, having the transmission fluid exchange done mechanically vs. draining, refilling, draining, refilling, draining, refilling...SynisterQ wrote:
Yep, the ATF passes through the radiator tank all the time, so as the engine coolant warms up, so does the ATF - but only after the thermostat opens up. Before then, the ATF gets no heat assist from the engine.oldmako wrote:My car goes from stone cold to half throw on the coolant temp gauge in 3-5 minutes at 1800-2000 rpm. And I have heat in the cabin shortly after as the thermostat opens up...so that tells me that my trans is only "cold" for a very short time. If I'm getting heat, so is the trans. Or no?
It is normal for the transmission to not shift into 4th gear until its warm. Its the kind of thing that you'd never notice until you live 10 seconds from an interstate on ramp (like me) and I got good at being able to predict when it would shift into 4th gear, on really cold days i'd be right at the Moreland Exit, but most days, the Glenwood Connector (references for the ATL folks).oldmako wrote:
This car however is not the same. I notice that the transmission will not shift into the final gear until the temp is at least 1/4" of the cold peg. I assumed that this was designed into the box, but from what I have read here that may not be the case. My trans has 125K and while the fluid is clean and it shifts smoothly, I really have no idea of how it was treated since 1999.
Thanks for the useful info
So, bottom line, cut and dried answer Q45Tech, are the transmission flushes that promise to get all of the old fluid out good or harmful? After all this reading, I still don't know the best answer to this question. There seems to be two sides, the side that swears by the total flush machines and then the ones suggesting the 18 quart fill and drain and fill and drain. I trust your answer but I believe you are in the latter camp. Can't wait for your response.Q45tech wrote:Carbon coating........humbug!. How do these psuedo expert mechanics expalin how a transmission works well brand new? without a coating?
These old wive's tales are there to explain the magical vodoo that comes from lack of education.
Never trust everything a mechanic says as they like doctors only know the limits of their particular education. Do your own research!
When you don't spend thousands of hours studying [automotive technology] everything looks magical.
