Samabra »
https://forums.nicoclub.com/samabra-u1847.html
Thu Apr 10, 2003 7:55 am
OK here's the whole story. This engine came modified from Japan, came with a Trust TD06S, 850 CC injectors, apex 1.2 mm head gasket, cams, and top mount manifold.
This car was my friends car and his project, and I bought it from him after the engine had been started once, after it had been put in the car etc. Well I bought it and brought it home. Started it up and took it on a test drive. Hit boost and then we shut it off for the night. It had an idle problem, idled from 1600 RPM to 2100 RPM continuosly. When the next morning came the car wouldn't start. I switched the aftermarket ECU, which is modded for the Z32 MAF and the injectors, for a stock ECU, and the car started. We then had to drive it to the muffler shop, well about half way there, the car hits boost, and when we shut it off, it won't start at all. Come back later and replace the plugs, which were completly fouled, and put in new ones. Starts again. Take it for another test drive, hit boost through three gears and the car dies on the way back. Coast to the shop. Open to the hood and there is oil all over the right side of the engine, it came outta the recirculater valve. No idea how the hell it started coming out the recirculator, in fact we still have no idea why its coming outta there but anyway, from that point on the car won't start. And it's spitting the air/fuel mixture out the recirculator valve. Well we get it to push start but if you take your foot off the pedal it would die, no sputter nothing, just die. And when my mechanic looked at it, he listened to it, and when you revved it you could hear the lower end knocking, so we knew the engine had to come out anyway. Also it would absolutly not key start. If you cranked it enough, and cut the gas supply to almost nothing it would stutter, but not start. So last night we pulled the head off and above is what we saw, I wiped the pistons off a little, but they pretty much looked like as above, and I have to say guys WTF!!??!?!?!?! I don't get it, any ideas? When we compression tested it it tested to about 70 PSI across the board, but is it possible for that to be all rings? Tell me what you think Thanks very much Chris Morrow
