PLEASE SOMEONE HELP ME GET THIS CAR RUNNING!!!!
coptic
Car: 1989 240sx Coupe
I just got my 240 and the previous owner added an alarm and sound system, I have an 89 coupe (non hud) and the engine turn over when you turn the key, but there is no power going to the spark plug wires. I am stumped and cannot figure out what the problem is. I looked a the fuse box in the footwell of the drivers side nad found that there are no wires or fuse going to the fuse on the lower lefthand side, named" Electronics (ig)"
the car has a soch ka
Could this be my problem? I have no idea like i SAID, BUT YOU GUYS ON THE FORUM ARE THE MOST KNOWLEGABLE BUNCH OF NISSAN TUNERS OUT THERE SO IM SURE THAT YOUVE GOT AN ANSWER. Just a side question the wires that come off of the white box on the back of the ignition module, where are they supposed to be connected if they are at all?thanks soo much in advance for your helpPlease reply to [email protected]
180fan
Car: 89 fastback
check the coil yet? Or the resistances in the wire that runs from the coil to the distributor? How about the distributor cap and rotor?
CDE
Car: 1989 240SX
180fan wrote:check the coil yet? Or the resistances in the wire that runs from the coil to the distributor? How about the distributor cap and rotor?
The distributor cap is ther first thing I would check. Make sure the rotor spins and that it is making good connections to the cap.
s13sr20chris
yup, dizzy has to turn to get spark.
