PLEASE SLEEVE ME!!!
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
NIZMO11
Car: 350Z
Performance Motorsport, is the leader in high performance technology for the VQ35DE. We have achieved absolutly amazing HP numbers through intense research and development, with no shoulders to stand on. I have recently been authorized to offer the same parts used in our Pro & Street Tire Car to the public. Our Sport Compact PRO-RWD 350z has excess of 1600hp to the rear wheels, making it the most powerfull VQ35 engine on the planet. The one component that allows us to run the numbers we do is the steel sleeves intergrated into the VQ block. I am sure that most of you are familiar with this process, so not much of this is a suprise. Many production cast iron and aluminum blocks suffer from a design weakness of cylinder stability by nature of poor support at the upper deck area, causing cylinder high pressures to leak into the water jacket. The manufacturing process of "cast in sleeves" provides for economy of scale in low horsepower engines, but does not accommodate high horsepower, high boost, or larger bore sizes. The enhanced water flow in and around the flange area is possible because of ported water flow control engineering called "swirl coolant technology". There is a different engineering model for each engine and cylinder design. While heat is generally considered to translate into energy, high resident heat in the combustion chamber can lead to detonation, the single highest cause of engine failure in the high horsepower regimes. High RPM normally translates into efficient scavenging of air-flow but during misfires or incomplete flame propagation, high cylinder pressures and temperatures are created. Our MID (modular intergraded deck) compensates for this high resident heat soak condition. If you have any questions about this technology, or would like pricing, please call me using the number listed below. I will be giving 10% off to anyone who mentions NICOCLUB.COM.... Hope to hear from you soon.
To see our record breaking 1/4 mile run using the methods previously mentioned please copy and paste the following link into your browser.
http://www.theexperience.com/recordrun.htm
Take Care,Nick AnastasiPerformance Motorsport, NY516-942-2996516-942-8249-fax linehttp://www.THEEXPERIENCE.COM
NIZMO11
Car: 350Z
Here is another pic of our sleeves for the VQ35 engine:
Thanks again, Nick AnastasiPerformance Motorsport, NY516-942-2996516-942-8249-fax line
RECORD BREAKING RUN AT MAPLE GROVEhttp://www.theexperience.com/recordrun.htm
NIZMO11
Car: 350Z
AND ANOTHER:
USsil80
if i am not mistaken i saw your company down in bristal with a silver 350 with street tires... the car was awsome and very clean....pro car(red one)is nasty is that going to run in pro outlaw in ndra....
NIZMO11
Car: 350Z
Yup, that was us. Thanks for attending, and showing your support. \
Talk to you soon,
USsil80
no prob.. you guys had one hell of a nice car... one of the cleanest cars i have seen... and the guy i talKed to was really nice, let us in the ropes to poke around the car.. hope to see you run again soon...
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Very impressive. Resloves most of the open deck design deficiencies.
Now how about something similar for the VK45DE?
Return to “Advertisers' Marketplace!”
