TheOtherJeff »
https://forums.nicoclub.com/theotherjeff-u158280.html
Tue Feb 01, 2011 4:22 pm
I've written 2 posts on this forum so far, both last spring. One was about the horrible performance of my EX in the snow, and the other asking for replacement tires recomendations. I think the original Dunlops performed great on dry pavement, but they wore out very quickly. I also suspected the poor snow performance was likely tire related.
Well, I bought the Yokohama AVID ENVigor's from Tire Rack and they've been all right. I drive pretty hard and the new tires don't provide quite as much confidence in hard cornering as the Dunlops did. Don't get me wrong, they're pretty good. It's just that the Dunlops had grip that didn't quit, and never felt like they were about to let loose. The Yokos seem to 'roll' a little, just for a split second, when taken to the limit, which scares me and takes away the sureness that I'd become accustomed to. If you don't drive like me, you'll have nothing to worry about. Even if you do, it's not something that surfaces often.
Now that I've finally got to try the Yokos out in the snow, I think they are a little better, but that may have more to do with tread wear that the tire difference. My only previoius winter was on well worn tires. Either way, this car still sucks in the slippery stuff. I seem to be the only one in the forum that has this opition, but this is the scariest car that I've ever had in the snow. It's an AWD w/18's. My last car was an AWD Murano, and it was a champ in the snow. As was the GTI before it, the Bronco before that, the S10 Blazer before that, the Corrado before that, the fullsized Blazer before that, the Sciracco before that, and even the '69 Camaro before that. I don't want to hijack your thread, so I'll leave it at that.
As for tread wear, I still have less than 10k miles on them, but it's clear that they'll out wear the Dunlops by at least 50% or more. I only got 18k out of them, and should have replaced them after 15k, but I ran them all the way to the wear bars.
Bottom line, the Yokos are pretty good. Not quite the grip as the Dunlops, although they are also called "High Performance All-Seasons". They are reasonably priced, I paid $664 including shipping for the set, plus another $60 for mounting & balancing by the local Nissan dealer. And they look to be much longer lasting. I'm expecting 25-30K, they're waranted for 60.
I hope this helps. I was (and still am) surprised that there isn't already a sticky post full of tire info like most other forums, but EX posters apparently care less about tires than window tinting :-)
