Please read z brakes
98240
Ok i got new brembo rotors and the only way i could get the z brakes on was to take the shims off the back of the brake pads well when i did that the calipers fit right over the rotors. But then when i got everything mounted on i noticed that the bolt that attaches the caliper to the car was hitting the rotor not only that but the rotor was also hitting the side of the caliper how can i fix this? Is the rotor the wrong size i have the 30mm 91 z calipers and i got the rotors from nopi I really need some help on this.
Modified by 98240 at 8:52 PM 1/12/2006
Modified by 98240 at 9:01 PM 1/12/2006
98240
the rotors are brembo blanks
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Are you sure they're rotors for a '91 Z and 30mm?
No Bolts should be near the rotor face... can u get pics?
Can't really help u until I have more info...
-Dan
hannibal
Car: Red Line to Glenmont
^ yeah, the caliper bolts shouldnt be near the rotor. Are you using the stick 240sx bolts??
KFL
Car: S14
what does the rotor have written on it..should max # ( mm resurface)Are you sure that you have 30mm calipers, if you had 26mm caliper+30mm rotors then that would have the bolts hitting the rotor.
98240
yes i am almost positive i have the 30mm calipers. I measured them today and it was about 1 3/8inch the rotor says #28mm The rotors are about the same size in width they are about 1 3/8inch i dont know what is going on here but i will take pics today and post them up
98240
is that how tight the calipers are suppose to fit in the 30mm rotorsif that pic isnt showing then here is a link to the pic
http://hustlecoke.com/randy/IMG_0259.JPG
Modified by 98240 at 2:20 PM 1/16/2006
hannibal
that looks way too close. The rotor shouldnt touch the body of the caliper. That looks like 30mm rotors in a 26mm caliper...
SPIRONIUM
Car: 240RS group 2
you MUST use 240sx caliper bolts to bolt on the Z calipers, the z bolts are different and will touch the rotor when bolted on the 240sx knuckle
98240
i am using the stock 240 bolts i ended up using a 26mm rotor and it seemed to fit alot better autozone goofed up on my order
crzycav86
Car: 93 Nissan 240SX KAT
You should have noticed something when you measured the rotor.
1 3/8 in. is about 35mm. None of the z32 rotors were that thick.
98240
Modified by 98240 at 8:49 PM 1/17/2006
98240
should there be about 2-3mm on each side of the caliper body from the rotor does that sound righti remeasuredi wrote the wrong size for the rotor it is actually ~1 3/16so that explains everything
Modified by 98240 at 8:12 PM 1/17/2006
Modified by 98240 at 8:48 PM 1/17/2006
