is there a how to on this or pics of the guide so i can do it this weekend.wmdavis007 wrote:Sorry to hear that about your motor. I started reading on this website soon as I got my vert...which already had a blown up KA. So I found out all I could before I went back to rebuild my KA. I removed both guides. Good luck on fixing your ride. Everyone and anyone that hasn't taken the top guide off really should do it...it takes very little mechanical know-how. Great post.
Sorry. These should be it.
Yeah, it's good if you can do it when you replace the gasket, but still you should do it cuz there's no point on waiting for next gasket change. You know what I mean? I removed mine right away as soon as I heard noise for the first time.slip69 wrote:thanks!!!!!i just replaced the gasket a few months ago. if i knew about this then i would have done it. thanks again
IIRC, someone bought a 240 for like $500 from the old lady and it needed engine work. When he opened the valve cover, it looked exactly like yours. He posted pics in 240 gen forum I believe. The car was in good condition overall. I guess same thing happened to the lady, thought there was a serious engine problem and wanted to get rid of it quick.kg4wih wrote:here is some pics from my phone i forgot my camera.......
Well, first one to loosen, leave it there and last one to remove I guess. Isn't that supposed to be 'Tighten in numerical order'? Not 'Loosen numerical order' I wonder what matters when you loosen them. Anyway, it's critical to follow this when you tighten the bolts otherwise oil will leak.Mangudai wrote: The only thing that is confusing me is the 1 next to the 12
Sorry, man... You over tightened the bolt and stripped one of the holes. You should have been very gentle when you tighten the bolts. You have to do it in order and follow the torque spec to prevent such a problem. Well... all I can think of is helicoil. Someone just posted 'How To' a couple of days ago. Hope that works on valve cover. You better do it soon, otherwise you'll lose oil every time you drive.slip69 wrote:well i finally got this done and my engine doesn't sound like **** anymore!!but i messed up when i was placing the valve cover. i guess i tightened(is that even a word??) the bolts too hard and cracked the gasket. so when i took the car to work it freaking spilled oil all over the right side of the engine bay!!!!! and to makes things worse, one of the bolts will not tighten up anymore freaking figures!!!!!!but at least the engine sounds nice now
No airbags. Usually, you will see 'SRS Airbag' logo on steering wheel and passenger side dashboard on air bag equipped cars.Loki4815 wrote:did verts come standard with an air bag? Just wondering if I need to disconnect my battery when I remove the steering wheel.
Usually, but if you turn the radio up, you can't hear her anymore.Loki4815 wrote:did verts come standard with an air bag?
