Cyberkreig »
https://forums.nicoclub.com/cyberkreig-u962.html
Sat Mar 20, 2004 7:44 pm
Guys/Gals... a good friend of mine and owner of a BIG Nissan shop (JGY Customs) in VA was robbed last weekend. He is a big seller of RWD and FWD SR20DET stuff. This happened Friday night/Saturday morning in Atkins, VA. If you know where JGY's shop is, and saw anything, please report it to me. Also, please be on the lookout for SR20DET parts... Here's the list of what was taken.. it's sickening..
JGYCustoms, Inc. theft report
Item Quantity
VVL solenoids 1GATEWAY LAPTOP 1JDM CAM ANGLE SENSOR 4Gtech 1/4 computer 1T28 TURBOCHARGER 1JDM SILVIA MAF'S 3KA24E MAF'S 2JGY FUEL RAILS 2JWT B13 ECU UPGRADE 2JWT B14 VVL ECU UPGRADE 2JWT B13 ECU UPGRADE 172 LBS INJECTORS 3250 LBS INJECTORS 28FORD COBRA MAF 1OLD COINS 1SONY CAMERA 1IGNITOR CHIP 2WHEEL LOCK SET 2AUDIO, AND CD ROM CD'S. 1SR20DET RWD HARNESS 1KA24DE ENGINE HARNESS 1JGYBB37 1JGYBB37R 1JWT resistors 321989 240sx gauge cluster 1HKS CAM intake 272 step 2 1bag for camera 1JWT ECU for Justin 1
Utility Trailor with wood and rails 1straps for trailor 4
HEAVY THROTTLE HOT PIPE 4GREDDY ROCKER ARM STOPPERS 9S13 WALBRO FUEL PUMP KITS 2Nismo FPR 3CLUTCH SPECIALTIES 6 PUCKS 3RWD FIDANZA FLYWHEEL 3FWD ACT XTSS 2APEXI AVCR BOOST CONTROLLER 10GREDDY PROFEC B SPEC 2 3GREDDY TURBO TIMER 2TURBO TIMER HARNESS 2HKS BOV FLANGES 10TURBO XS RFL BOV 2GREDDY TYPE R BOV 1CROWER TITANIUM RETAINERS 3SR20DET CAMS 2ARP HEADSTUD KITS 5GREDDY HEADGASKET 3EAGLE SR20DET RODS 2B13 WALBRO FUEL PUMP 4COBRA MAF'S 7TOPSPEED INTAKE MANIFOLD 2TOPSPEED FOAM AIR FILTER 15FORGE INTERCOOLER 3GREDDY FMIC FOR S13 11DROPEZONE SPRINGS FOR S13 1DROPEZONE B13 SPRINGS 1TOPSPEED SENTRA COILOVER KIT 3KOYO S13 RADIATOR 1JDM SILVIA GRILL 1JDM SILVIA HEADLIGHTS 1GREDDY DOWNPIPE 1HOTSHOT SPEC V HEADER 2HOTSHOT SPEC V COLD AIR INTAKE 1JWT S3 CAMS 1CALIFORNIA CAR COVER FOR B13 SENTRA 1B&M FWD SHORTSHIFTER 1CYBERDYNE FUEL PRESSURE GAUGE 41
CASH 1TOPSPEED B14 REAR MUFFLER 1TOPSPEED CAV INTAKE 1KOYO S13 RADIATOR 1GREDDY INTERCOOLER 1TOPSPEED J PIPE 1AIR FILTER 2BANANA DRIFT MOUNT 1GREDDY TURBO TIMER 1B14 COILOVER KIT 1HOTSHOT SPEC V HEADER 1EDLEBROOK N2O BOTTLE 1PLASTIC TOOL BOX 1PIN LIGHT 2JDM SILVIA PRODUCT BOOK 1HKS BOV 1
NGK spark plugs 32VVL harness 1u13 harness 1B14 FSM 1Battery Booster 1Gti-r motors 11 VVL motor 1Hotshot intecooler kit, 2Hotshot partial kit 1Eagle Rods 1RAS, GREDDY 1Greddy oil pan 1S14 FSM 1VVL solenoids 2
JWT S3 CAMS 1JWT ECU UPGRADE 1HKS CAM GEAR 1HKS INTAKE CAM 1HKS EXHAUST CAM 1GREDDY HEADGASKET 1GREDDY ROCKER ARM STOPPER 1HOTSHOT PIPING KIT 1JGY FUEL RAILS 25FASTBRAKE SPEC V UPGRADE 150 LBS INJECTORS 4INJECTOR PLUGS 4FORD COBRA MAF 1CYBERDYNE FUEL PRESSURE GAUGE 1GREDDY TURBO TIMER 1TURBO TIMER HARNESS 1APEXI AVCR 1AUTOMETER BOOST GAUGE 1KA24DE HARNESS 1SR20DET HARNESS 1APEXI AVCR 5AEM WIDEBAND UEGO 1JWT ECU UPGRADE 1HOTSHOT FRONT MOUNT INTERCOOLER 1JWT ECU UPGRADE 1PHANTOM LSD with green springs 3GREDDY HEADGASKET 1PAR CONNECTING RODS 172LBS INJECTORS 4JGY FUEL RAILS 1GREDDY ROCKER ARM STOPPER 1JWT S3 CAMS 1JGYBB37R 1ACTUATOR FOR TURBO 1SPEC STAGE 3 CLUTCH 1CUSTOM COMETIC 90MM HEADGASKET 1CUSTOM CP PISTONS 90MM 1EAGLE RODS 1HKS SLEEVES 1GREDDY ROCKER ARM STOPPER 1
DIE GRINDER 1AIR RACHET 1PRECISION TORQUE WRENCH 1RACHET WRENCHES 1ELECTRICAL CRIMP/STRIP TOOLS 1U- JOINT SOCKET SET 1LARGE SET OF METRIC AND SEA WRENCHES 1IMPACT SOCKETS 15 RACHETS 1VARIOUS EXTENSIONS FOR RACHETS 1FLAT TIP SCREWDRIVER SET 1PHILLIPS SCREWDRIVER SET 1MANY MISC SOCKETS, 6 PT, 12 PT, DEEPWELL. ETC 1L.E.D. MECHANICS LIGHT 1HOSE PLIERS 1TOOL CHEST 1SAFTY GLASSES 1
KA FUEL RAIL 1WALBRO S13 FUEL PUMP 14 INJECTOR RESISTORS 4FWD FIDANZA FLYWHEEL 1PLACE RACING MOTOR MOUNT KIT 1S14 INTAKE MANIFOLD 1APEXI AVCR (SARKIS) 1
Tin Snips 1Punches and Chissels 11 set of wrenches, 8mm to 32mm 11 set of rachets wrences 8 to 22 1Socket set with extra sockets 1extensions/swivels, impact sockets 1breaker bar 1Torque Wrench 1Air Tools 1Torque Wrench 1cheap rachet wrenches 1channel vises 2
1 gti-r motor 1Greddy Intercooler Kits 6Turbo Brackets 6Fuel Rails for Gti-R 15Apexi N1 1
Edlebrook wet nitrous kit 1Apexi Avcr 1Injector resistors 4NGK plugs 4Apex'I turbo timer 1SPW water temp gauge 1Autometer phantom boost gauge 1Autometer phantom a/f gauge 1Walbro fuel pump 1B&M shifter 13" downpipe 1Clutch Masters stage 4 1Fidanza Flywheel 1fuel injector plugs 4Greddy Type r BOV 1300zx maf 1Hotshot intercooler kit 1Greddy oil catch can 13" testpipe 1Ground Control Coilovers 1JWT ECU for 72lb 1
I know it's a long shot.. but please let me know if you see ANYTHING suspicious as far as sales online. If you happened to be in the area, and saw a truck.. or whatever.. please let me know. ThanksTravis
