Please Read!
9095240SXDUCK
Car: 240SXs
Ok
I just got me a 90 240SX FB with a RedTop SR in it.
The car has no P/S.
What Do I need to make it to have P/S? I know there is a P/S pump on there right now but As I know of its from the Clip/SR P.S Pump.
Also When Ever I start the car in the Morning, the car wants to die or Idle around 300-600 RPM. But when it get warm up it run like a Champ Idle around 700-850. A customer that came by my Work also has a SR S13 FB told me to use a B12 or B13 Throttle Cable Holder!!! has anyone heard of this before. What do your USE?
Any Bit of help would be Thanks
SpeedRacer1
Car: 1990 240SX, G35
PS Parts:PS fluid resevoir from the SR clip or DOHC KA car.fluid line from the resevoir to the ps pump (can make yourself)PS pump from SR or DOHC KA.PS high pressure line (need DOHC KA line, or rebent SR line)PS low pressure line (can make yourself)PS beltPS steering rack (should have come with the car)
rudee023
Car: '03 Infiniti Q45
Yes, a throttle cable holder from a an SR20DE will bolt right on with no modification. Got mine at the junkyard.
9095240SXDUCK
Car: 240SXs
rudee023 wrote:Yes, a throttle cable holder from a an SR20DE will bolt right on with no modification. Got mine at the junkyard.
Any FWD SR20DE car?
Thanks for the list SpeedRacer1!!!
