Please Read: Sr20det Transmission won't come out.
JdrifterCA
Car: 1992 240sx LE
Hello, I have a s13sr20det black top in a 1992 240sx. I'm trying to replace my throw-out bearing so my car would run tomorrow for my senior project final presentation. If i dont present, i won't garadurate. SO please help me out. All the bolts are off, the bellhouse to motor and back to drive shaft. I droped the transmission out now is down at an angle and the bellhousing wont clear. PLEASe HELP HELP HELP thank you.
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
Back off the 4 bolts on the K member(the front sub frame). This will lower the entire motor and transmission enough for the bell housing to clear the tunnel. If you think it's hard to get out without the K member bolts backed down just wait until you tried to put it back in.
JdrifterCA
Car: 1992 240sx LE
where is this k member thing? what size? so i can guess which ones it is. Please post a picture or a good description of where and what it is. Im still learning and i only have 9 more hours before my life will be over.
Hijacker
Car: '92 240sx Convertible
'94 F-150
The K member is the front crossmember. It's under the motor. However, I recommend not doing that. Those 4 bolts on the cross member are pretty much the only things that are keeping the motor from falling on you and crushing you.
I'm assuming you've pulled the driveshaft, the transmission crossmember, and the starter. You need to take a few prybars and insert them between the motor and the bellhousing and just start working it back. Put one prybar on each side and just slowly work it off a little at a time with each prybar. It will eventually release from the clutch and fall onto your jack.
6bolt4g63
Car: 1990 S13
I dont see why its not coming out, unless something is still connected. Double check to see if nothing is getting hung up. Sounds like the clutch is hanging up on the input shaft in the trans.. maybe jack it back up and pry/wiggly it again to see if it drops. When i was installing a trans in a 95 240 i had to mess with those K member bolts to help it clear the tunnel... but i had another jack supporting the engine and i was careful. Good luck.
Thrasher068
Car: 91 240sx
Well the only thing i can think of is it hitting the firewall u can jack loosen the motor mounts alittle and jack up in the engine alittle but be cairfull not to crush anything IE OIL PAN even a small dent can be a total loss for the motor depending on location... If that doesnt work look all around the transmission and remove the last bolt that everyone missed. Also did u remove the starter? if that is still in then the wires and it hittin the manifold can hang it up
