martin »
https://forums.nicoclub.com/martin-u2584.html
Wed Jan 08, 2003 8:30 am
I don't know anything about the E6 ECU, but you said that you sent it to HT for testing. Presumably it came back OK? WHich probably means they plugged it into another car there and it worked.
I'd suspect the harness, who did the harness? What did they start with? I'd pull the harness out, and do a pin check on it, from ECU to igniter, ECU to dash connector, to plugs F8 and F9 - **** I'd check everything I could think of. I'd check the plug from teh dash to make sure I had +12v, +12 while cranking, etc.
-Martin.
