ginostef »
https://forums.nicoclub.com/ginostef-u13722.html
Fri Feb 20, 2004 5:25 am
The throttle cable attaches to a rotating assembly at the throttle plate, so if this is closing on it's own, there is no spring involved to check. When you hooked up the cable - did you put both the nuts on it? One goes on one side of the mounting plate, the other on the other side. Without both, the cable will move and pop out again. Next thing - when the cable came off the pedal - where did it come off? inside under the dash? If so, there is a pin and cotter key that places it high up on the pedal - did you put it back where it came from or someplace lower on the pedal? Since your pedal is sitting higher now, my guess is you attached it to the wrong spot. If the cable is attached, then it ain't broken, so replacing it is not likely to fix the problem. This cable can be 100 feet long, but it doesn't matter so long as you have it attached tot he pedal where it belongs and to the throttle plate where it belongs. good luck!
