squonk »
https://forums.nicoclub.com/squonk-u91456.html
Thu Feb 26, 2009 1:59 pm
93 240sx Vert
So Today I got a bright idea to do a tune up to my car. *new plugs, new wires* due to a misfire I was experiencing but it was very subtle. After I f***ed up by buying the wrong plugs, my engine decided to do a huge jump in the car. I immediately shut it down. I replaced the Bosch *plats* with NGK *don't ask*. Anyway, I put new wires on, they are on correctly *I quadruple checked this myself as well as having a guy from Napa and the book as a guide.* I still was experiencing a misfire. So I replaced the distributor cap *I took it off and noticed a very small tear in it*. After that failed, I replaced the rotor. Still misfiring.
Napa said maybe a Vacuum hose came disconnected or leak in that area.
The problem I experience is no longer subtle and it only seemed to be my fault to begin with so please if you have any suggestions on how to check the leak on the vacuum hose, or another idea of what the problem might be..
