PLEASE!!! Need help with front end problem.
casey115764
Car: 1990 240sx hatch
Ok I bought a 240 about 6 months ago and took it for a test drive when i stepped on the brake the car would shoot left or right. so i put it on my lift and noticed the right lower control arm was loose and the hole was wobbled out, so i replaced it and got new tires. That was about 5 months ago then about a month ago i noticed my handling starting to get worse and worse it would bounce around and then i noticed my front tires were completely bald on the inside and out so i put it back on the lift and noticed it was way out of alignment so i replaced the other lower control arm and both tie rod ends and took it to get an alignment. well today the handling is the worst its ever been i cant even drive it its so bad. It goes wherever it wants seems to do it way worse when i am on the brake or when ever more weight transfers to the front. I couldn't see it already being out of alignment being it was only yesterday that i had it aligned.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Were the holes on the subframe elongated from the LCA?
Also, how shot are the tension rod bushings?
casey115764
Yes but i welded washers onto the sub frame so its not elongated anymore. The tension rod bushing are pretty worn right before this i just called to get prices cause i was just under it and noticed they are deformed but not completely rotted away could that be the problem?
