frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Tue Sep 07, 2004 2:51 pm
"When the engine is in TDC, the rotor should be on cylinder 1????or turn 360 degrees again....but it should be on cylinder 1, right??"
Yes, rotor SHOULD be on cylinder 1. If not, turn the crank 180 degrees, not 360, 360 will bring you back to where you started. If the distributor still isn't on cyl 1, then something is wrong. Take off the valve colver and see the position of the dots on the cam gears at TDC. I believe they should be 11 and 1, intake and exhaust respectively. *Consult a search for a positive on that* It will also give you further information on how to fix the problem.
"When the engine is in TDC whats the actual position of the distributor?"
At TDC the distributor should be pointed at cylinder one.
"Should it be in middle position??? To be able to adjust either way???"
No, it shouldn't be in middle position. There may still be play, but if you can't make it line up, then try the next possible solution (go down)
"I just want to make sure I check the default timing positiona and make sure that the pulley is on the right marking.......sorry If I confused anybody..."
Make that your last resort. I had a similar problem to you and my distributor was 180'd out. Try taking the plug wire from cyl 1 and put it into cyl 4, and vise versa. Its a common problem that may be the solution for you.
