Problem I have is, no traction whatsoever. I drive fully street S13 with CA18DET and don't plan to turn it into drag-only car. We race mostly at the track where asphalt is 50 years old, very little of asphalt itself remained, mostly small stone chips if you know what I mean. You should probably 700HP 4WD cars spinning all 4 tires to understand how bad it is.
On this tarmac I cannot get better than 2.0' 60ft, 8.05 in 1/8 (did cut 1.8' on concrete old airfield). I want to improve that.
A bit about my setup:
CA18DET, around 360whp (according to 1/4 calculators)
stock weight
lowered a little bit, stock shocks (I think?)
ET Drags (5 years old) in the back, 26x8.5-15", running about 10psi, +/-
I was thinking about different ways to improve launch - different gearboxes, diffs, adding weight in rear, even trying to get custom gearbox shafts fabricated (cause now 1st is useless). Wanted to launch in 2nd gear, too.
I also think my slicks are old now. Which slicks could I fit under S13 wings? Would wider slicks help?
Please watch a couple of my starts so you get the idea
http://www.youtube.com/watch?v=iMkLMXXEJTw - you can see how I change early and immediate loose the run
http://www.youtube.com/watch?v=0essyWeFfHw&t=368s - few starts here
http://www.youtube.com/watch?v=0essyWeFfHw&t=483s - few here, good comparison to Alfa with similar power and RWD
I hope I gave main info about my car
