underground57 »
https://forums.nicoclub.com/underground57-u18524.html
Sun May 28, 2006 5:41 am
In your other thread, you stated that you had 5 lug hubs, so the wheel isn't going to work anyways. Why ask about it? And hypothetically, even if you had the same bolt pattern, 8.5+43 will most likely hit your coilovers and won't fit, unless you've got a rediculously sized spacer, something I don't recommend. and the 11's aren't going to fit happy either. 17x9 +23 is tight, so you can imagine how 18x11 +23 would turn out (or wouldn't, rather). And hypothetically EVEN AFTER ALL THAT, you wouldn't want to run that much of a difference between 8.5 and 11 if you had any intention of actually driving the car. Just because you've got the money, doesn't mean you need to be stupid about it.
