http://tinypic.com/view.php?pic=10zpbgh ... rhryid&s=5
Those are 3 pics of the ACT
Ok, I am about to sell my S13 that I have had for 19 years!
I had a ACT HD clutch installed 6 months ago. After 2000 miles it started to have problems dragging and then I could not get it into gear at all. I had it toad to the shop and they took it apart and this is what happened to the ACT Bearing. I have had problems with the ACT from the day it was installed. Stiff clutch, Chatter, whining noise when the clutch was not depressed and then would go away when clutch was depressed in gear or in neutral.
Well I bought a Exedy Stage 1 and this thing is so stiff it is like pushing in a manual from a 70 Boss 409. It chatters, I hear the same whining noise & really cannot drive it. I think the whining noise is the impeller shaft in the transmission (that is what someone said). I forgot to mention that I drove the car about 400 miles with no gear oil in the transmission. Not my fault the shop did not check it & when I pulled the drain plug it was bone dry, so I think I fried the trans. But I cannot figure out why the clutch is so hard to press in. Another person that drove it said something has to be binding or maybe the fork is bent or the ball is damaged. I really do not want to bring it back to the same shop because I feel like they might not know what they are doing.
Anything to look for? Everybody says it is in the adjustment & you really cannot adjust the clutch except a little at the pedal which was done. Put in a new master & slave which did not do anything.
I am so aggravated & maybe after 19 years it is time to move on. I just spent tons of money on a new KA which was a mistake so I am really going nuts. Could they have put in the clutch in backwards?
T H A N K S
