Slumpert »
https://forums.nicoclub.com/slumpert-u216156.html
Sat Mar 23, 2013 9:29 pm
The HOT top hose is a result of minor ebbing of coolant as the waterpump is circulating in closed loop due to the themostat being closed/pressure pushing coolant into the overflow tank. It is amazing the amount of cooling that these engines can accomplish without the radiator.
Figure 3 cut up might work but yea just use thin bead of RTV is what the manual calls for. The water outlet pipe on mine was badly corroded to the point I could not re-use it in peace.. I was able to buy a third party replacement for $15 at the auto parts store. Even though it is triangle shaped, the holes are not evenly spaced so you need to be sure the "marked" side is up. I messed up and had to redo the RTV when I tried to put it on rotated.
Once I replaced the waterpump, themostat, and radiator, both hoses get nice and roasty toasty when warmed up, and she has not overheated since..
