[s3] »
https://forums.nicoclub.com/-u-u9889.html
Fri May 14, 2004 7:10 pm
The FSM lists 3 possibilities to check
1) Harness between ECM and AT Control Unit2) Dead (weak) battery3) A/T Control Unit
Number 2 is ruled out since your car starts
I would say its probably the A/T Control Unit itself, its next to the brake pedal. You can remove it fairly easily and buy a new or used one. A new one would probably be...pretty expensive.
Yes it would have something to do with you stuck in 2nd gear all the time.
