Ziggy1621 »
https://forums.nicoclub.com/ziggy1621-u205397.html
Wed Jan 02, 2013 9:23 pm
The pump will turn on for a split second as long as you wait 10 seconds between tries. To make sure it is working, pull a line off at the fuel filter, direct the line into a bucket and turn the key to the ON position, fuel should begin pumping into the bucket. If nothing, then the pump may be bad, or relay. If you have fuel being delivered, you can build a pressure gauge from lowes. I just bought the parts to test mine today. I believe my fpr is bad, so want to test it. I've removed the dampener as it is unnecessary, you can do the same if you would like, just be sure to cap the vacuum line that went to it. After you test for pressure, you can find out if the fpr is good or not. A bad fpr will allow the fuel to leak back to the tank prematurely, therefore giving low pressure
