Please help with water line identification and heater hose install. (Pic)
JDMbyBlood
Car: 93 240sx Coupe
Whats up guys. I'm in a little bind. Can someone tell me what water lines are used in the back of the SR engine and how does the heater hose kit install. I cant seem to figure out how to install these darn hoses. Thanks guys.....
ser2102
Car: 91 dead. 90 getting did
the short hose will connect to the pipe thats on the passenger side of the engine. the one with the really orange inside shown in the pic. route that hose to the upper heater core inlet.
then the hose on the motor that is cut in your pic, remove.
the stock rubber piece that is above the transmission can be removed, and use your new long hose to connect that to the lower heater core hole.
also, that little elbow that comes off the higher tube in the back, thats the turbo coolant line.
ser2102
hope that clears it up
JDMbyBlood
Car: 93 240sx Coupe
ser2102, Thanks a million for taking the time to show me what goes where. The picture you modified helps ALOT!!! I take it that the hose kit I bought is the correct one? Thanks again.......
