please help with tire size.
danzan240
Car: 1989 nissan 240sx
I found some wheels that i would like to get for my 240. they are 16x8's with an offset of +0mm. What size tire would be the best for me? id like to get as much tire on the road and it not be too much. and also would i have to do anything to accomodate the width of the wheel? like get a spacer or anything like that?
thanks for the help in advance.
danzan
tramp_drift240
Car: 1992 240sx SE Coupe
sounds like a sportmax 002.
do math, son. turn the 8 inches metric, and itll give you a rough tread width to shoot for. then you take the stock outer diameter of the wheel, and find the right sidewall to make the tread width work properly.
seeing how i dont go for all that beefy stuff, i cant really help you all that much. but its not hard to figure out.
do homework.
also, why do you want to use spacers with a zero offset wheel? how far are you wanting the wheels to stick out, exactly?
adrianfromthecastle
Car: 1992 Nissan 240sx
no spacers needed.
205/50/16.
any wider or a tire and you might have to pull your fenders.
danzan240
i dont want spacers. i was just asking if i would be fine w/o them. 205/50/16? cool. i found some kumhos that i like on tirerack. thanks for the info
danzan
Modified by danzan240 at 12:20 AM 11/27/2008
