mikey300nc »
https://forums.nicoclub.com/mikey300nc-u165312.html
Tue Aug 10, 2010 1:35 pm
thanks guys! im pretty sure its the flywheel because both time i had it resurfaced the step wasnt there and did the same exact thing both times. ive bleed my clutch 3 times so far, i even got a new slave cylinder. ill try bleening it again to see if its better but if it dont ill baby it til funds will let me get a new flywheel! the only mods done to it is its a jdm engine, the clutch, fmic, z1 1 piece drive shaft, a hi/lo boost setting from 8 to 14 psi, i have custom screamer pipes which makes the turbos spool so much faster and sounds great, with full 2.5 open piping all the way back to stock mufflers to keep it a lil quietier.
