skyliner »
https://forums.nicoclub.com/skyliner-u9013.html
Thu May 12, 2005 2:40 am
Hi Speedracer, ... actually i've searched on these forums quite a bit, and was hoping you'd respond.
I wont touch my timing then, ill play with the TPS to get my power back.
When i say fail safe mode, i mean limp home mode, as in i can't rev past 2400rpm, and the problem comes and goes, sometimes it hits it, and i can keep the revs constant and it jumps back up and revs higher, then hits it and waits till i let off the trottle and then the fuel cut goes away. Other times its really pronounced. I was reading the FSM, and it said that the ECU only goes into this mode when there is a problem with the MAFS, on a random website, they say the coolant temp sensor can do this too, im doubting that though.
I've tried to fix these problems (ECU reading TPS and MAFS), i've replaced my TPS, and it made a huge difference in throttle response, so i doubt that it is the problem, plus i've heard ... well from you, that you can run without the TPS. I've changed the MAFS, i've checked the wiring from the MAFS to where it goes into the protective grey wire (with the insulating ground), and i've checked conductivity from that point to the ECU, it was good, i also checked the insulating ground to the MAFS signal wire on the ECU, there was NO conductivity, so im assuming that its not shorted from that point to the ECU ... I also added an extra ground from the connector to the MAFS, to the body.
I'm glad that the ECU light being on while im driving isnt a bad sign, but it never used to be on while i drive (this was before i started code checking though).
I'm running out of time and wits with this car. My next step is to by pass the main harness with the MAFS signal wire, ie, solder a new wire to the MAFS signal wire, then run that beside the main harness and then solder it where it reaches the ECU. If there is a short somewhere, this should stop it from effecting the MAFS ... keeping me out of fail safe mode.
If this doesnt get rid of the code , well im out of ideas, maybe the ECU is garbage.
