Please Help With My A/F RATIO GAUGE!!!
pearlwhite95
Car: work,my whip and my marine fish
does any one know what wire to splice into to get my A/F ratio gauge hooked up? ive been tampering with it but no luck. please help would like to get going A.S.A.P.
Tictakman
the signal wire is the one from the o2 sensor on the stock header.
Zak
pearlwhite95
yea, but doest the correct one come from the ecu? because when i hook it up to the o2 sensor it gives really weird redings.
pearlwhite95
is that where you hooked yours up to? and if so did it work right?
Drift Machine
Car: 1991 KA-T 240sx
Yeah don't really expect any extremely accurate readings from it.
nismo1003
Car: Ka24de
from what I know is that there are three wire from ur stock O2 sensor ( i have a OBDII) anyways, there are two white wire, and u can use a voltmeter to test it it is between 0-1v , and that wire goes in to ur ECU , all u need to find that pin and hook it up there, it shoudl going up and down all the time except idle ( well at least mine does AUTOMETER)
nismo1003
Car: Ka24de
I agreed with Drift Machine , it is not accuary lol... I like my WB...lol
Tictakman
ya its not the most accurate gauge. if you want accuracy get a egt gauge. anyway, i have obd1 and all i did was splice into the 02 sensor wire. how is it acting weird? does it constantly shift back and forth? if so that is normal, it is trying to balance out. it will always do that
Zak
