whitelines13 »
https://forums.nicoclub.com/whitelines13-u35465.html
Sat Sep 16, 2006 5:43 pm
FIRST & FORMOST THANK YOU FOR YOUR TIME ..I RECENTLY BOGHT A VERT AND SWAPT THE DASH OUT ..BUT WHEN I CONECTED THE CLUSTER BACK IT WAS ALL VERY WRONG .. NONE OF MY GUAGES WORK ..SPEED. RPM. FUEL.TEMP. TURN SIGNAL'S EVEN THE DIGITAL CLOCK NOTHING . & THE CLUSTER DOES ILLUMINATE MOMENTARILY .CHECK ENGINE LIGHT STAYS ON WITHOUT THE KEY IN THE IGNITION SO DO THE SEATBELT LIGHT STAYS ON ..I CHECKED JUST ABOUT ALL THE FUSES THE CAR DOES RUN AND DRIVE TOP DOES WORK SO DO THE HEADLIGHTS.. I JUST NEED TO DESPERATELY SOLVE THIS ISSUE AT HAND .. ANY POSITIVE FEEDBACK WILL BE EXTREAMLY APRECIATED..THANK YOU .PEACE.
