Please Help with Door Panel/Alarm Questions????
robbie82lv
Car: 1993 Infiniti J30 Base Auto Transmission
I've gotta 93 J30 about a week ago my alarm clicker stopped working so I replaced the battery on the remote. No luck. I checked everything with the alarm and it seems to be in working order. I started using the key to manually open the door locks then it started to where I'd turn the key twice all the other doors would unlock but the drivers side door lock would stick some times. Then this morning I couldn't get the drivers door to unlock at all. Even when I push the lock button or try to manually lock it the door won't lock. The alarm isn't working from this because the door sensors reading the driver door as open that much I know but for some reason I can't get the door panel off, embarrassing I know, but I removed all the screws lifted, pushed, pulled, and everything else and the door panel won't come off. Couldn't find anything in the owners manual so I'm hoping you guys can help. Thanks in advance.
yodawill2000
Car: 94 Infiniti J30
