240sx man »
https://forums.nicoclub.com/240sx-man-u13221.html
Tue Nov 16, 2004 2:13 am
First I want to thank you for taking the time to e-mail, here is how it is going, still idle hunts, here is some history, the engine has 41,000miles taken from a car that sat for a year, the compression is 185 psi and the leak test is perfect, ,I really believe the valve for idle you describe is stuck, I still have the other engine that only smoked, laying right next to it, I was thinking of swapping the whole intake system, its funny, the old engine had glass smooth idle, even while smoking and not passing an emission test,also when I put the distributor in NO matter what I do , if I want to start this thing ,it CANT be what the book says, the rotor has to be turned more counter clockwise, not a whole lot but at least one tooth, I have really taken the distributor out ,10-15 times, and tried to make sure the rotor was pointing at #1. but it wont start that way, that is really odd to me....I know if the engine timing is off then you cant put the distributor in the factory way, is there a way to tell by pulling the valve cover off, that the engine chains are where they are supposed to be? thanks again for any help.
