kuzals »
https://forums.nicoclub.com/kuzals-u33926.html
Wed Nov 30, 2005 3:37 pm
I have a 1989 left-hand drive 240sx.
I'm getting white smoke so I thought I'd try some gasket/block sealer. To do that, I need to flush/fill the cooling system. I did a flush sort-of according to instructions, thinking I could get away without using the engine block drain. This failed, as I can't fill more than three litres/quarts of coolant (they're about the same amount) into the radiator. Also, the coolant in there doesn't seem to be moving, even with the car on. Is that normal?
I have a Chilton's manual (hasn't been of too much use so far) which doesn't tell me where to find the drain plug, and has very sketchy, useless information about the air release valve (has some crappy diagram, nothing else).
I've also searched on these boards and I'm afraid I don't know enough about cars to find the plug based on other information (it's supposed to be near the O2 sensor?).
If someone could please post detailed information, or better yet a picture, on where these two items are, that would be really appreciated!
Right now, my car is sitting outside on the driveway, jacked up the front, and tonight's temperatures are dropping below freezing. I have the rad cover open in hopes that it bleeds itself enough to accept a normal amount of coolant/distilled water.
*fingers crossed*
