otterman »
https://forums.nicoclub.com/otterman-u37573.html
Tue Apr 24, 2007 11:04 am
As far as trying to reach around 400hp heres the order I'd do the motor in:1.)Fuel Pump2-4.)Exhaust system (exhaust, downpipe), clutch + flywheel, intake (any order)5.)Fuel system (injectors, Z32 Maf, ECU tune or air fuel computer)7.) Headwork (cams, springs, retainers, metal headgasket)6.)GT2871R
You wont need a stroker kit or any bottom end work for 400hp.
If you're wanting 5 lug conversion for bigger brakes, it'd be cheaper and just as good to get the brake kits for the 4 lug (fastbrakes.com). If you want the bigger rim selection too then 5 lug is good.
As far as coilovers and suspension, that's personal preference and what you want the car for. I just threw on struts and springs and I'm happy with my suspension while most others on Nico like more suspension work done.
Modified by otterman at 2:55 PM 4/24/2007
