deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sun Jan 18, 2004 10:01 pm
You cant tell timing chain problems by removing the valve cover and looking most of the time. One thing you can check is how far the tensioner is pushing the chain out (indicating slack) if your looking down from front it will be on the left and have a small cylinder pushing out on the left chain guide. If it is pushing out a 1/2" or more you have chain slack. Chain is probably rubbing against chain oiler peg if its grinding and you see this. If you notice your guides are broken or damaged (mainly the right) chain is all over the place.
ka24e has hydraulic valve lash adjusters, if one or more is severly damaged, it will click clack. When the lifters are dry they will take up to 30minutes to clear up or bleed with the engine running, You should only have to do this if they have just been installed or if they have been sitting for long period of time without oil flow. If you suspect its the lifters everytime you start up, instead of the timing chain, to much oil is bleeding out of them and/or weak oil pump.
