please help...what is the size charge pipe i can use with a stock ka mafs...
nsanesrt
i need to know the size aluminum pipe i need to best match the stock ka mafs....i am running sr20 injectors and want to run a blow through setup...i was thinkin 3 inch..but just wonderin if anyone knows....i dont have the car here in front of me....
also what is the charge pipe size i would use to match the sr20 t25 and sr intercooler...it looks like 2 inch or so...
thanks in advance...
nsanesrt
c mon guys i tried searching forever
toki
your engine bay + screwdriver + tape measure = answer to your question.
WDRacing
For intercooler piping connecting to the MAF you can use 2.5". I don't know what size the SR cooler uses. But I'd use 2.5 for everything and use silicone hose reducers if needed.
WD
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Stock S13 MAF is 2" ID...
I'd do 2.25" at a minimum, but I'd recomend 2.5". When you're off boost, you don't want some tiny piping that your motor has to work really hard to inhale through.
- Brian
:: orion ::
^^^ Beat me to it...
Great minds think alike...
WDRacing
LOL...true
AN89HATCH
How do you guys get the mass air to fit the charge pipe with out leaking? I know there is the mass air flow adapter plate, but is that good enough to hold by its self with out causing a boost leak? Or should you use something like silicone in between the mass air, and the adapter plate so there will not be boost leaks?
