devil_child »
https://forums.nicoclub.com/devil-child-u58421.html
Mon Mar 17, 2008 6:24 pm
Well, first head over to KA-T.org. Also search. I'm feeling nice, so:
Forged pistons, h-beam rods, new cams retainers and springs might as well do valves, new clutch, a good rear differential, Yes a turbo kit, yes a manifold, new headgasket, arp head rod main and exhaust studs, I'd suggest a holset turbo, a rebuild, new oil pump, new water pump, drain lines turbo feed lines, sandwich plate, oil restrictor, external wastegate, electronic boost controller, Engine management including timing control, wideband, quality guages, injectors over 550cc's, dyno tune, a better suspension, new mounts, a bigger MAF, new timing set, the stock transmission wont hold for long, probably a better driveshaft, Lots of other little crap ,Lots of time and money, and RESEARCH. Have fun.
I've left out a lot actually but meh, you can search for that. You know..... good practice
